I can pull one of my spares. Send me your address
I shipped him one of mine. He is going to pay you for the replacement which you can ship to me. >Came in today. Way too stiff because I had to thicken it up in order to print successfully. I'm going to grind it down to thin it up.
Ron - PM me your address and I'll get it sent out tomorrow.
Turned out pretty sweet though!
I'm thinking that the clip could be glued to the flap and do the job. It does not have to be a friction fit. As long as it stay oriented so the flat side is "up" it will time the flap to the spring.Ground the "base" down to let it flex. I think it's going to be a winner. Might try to modify the CAD model and see if they can print it that way.
Will also try to get around to modeling the tulip panel itself. I've been kicking a few ideas around on how I can get the geometry reproduced and have some ideas.
Didn't push it all the way on, but it was starting fine and didn't seem to be putting up too much resistance.Cool Looking forward to all the fun that will result from your work.
Did you test fit it on the flap I sent you?
The clip fit is very good. I have had it on and off three times. (maybe once backwards but we don't need to talk about that)I'm a dumbass - I should have measured before I sent them out to you so I could tweak dimensions before printing additional.
Even with your CAC (cheap ass calipers) can you tell me what you get measuring the pin versus the hole? If you can give me the delta I can adjust the model accordingly and get a few more printed for testing.
Glad the gap distance worked okay. I thought it would based upon checking it on your tulip panel you sent but didn't push it all the way on, well because if it didn't fit that would be an abuse of your components you entrusted to me. lol!
