Might I suggest that you measure the outside diameter of the pin, and then outside width of the clip with the calipers you have? Then Mr.Chicken can use that ratio to determine the required hole.The issue I am having is when I measure the inside dimension I get one number but when I measure the outside dimension I get a different number. They don't close. The two sides of the caliper are not in alignment.
