1 - 7 of 7 Posts
I need to replace a small hose that runs from the air intake to the valve cover (I think) on a 2006 2.4L Solstice. See the picture at the link below. I can not find anywhere where this hose is named or described. I think it is the PCV intake hose but am not sure.
Can someone tell me what this hose is and where would be the best place to purchase a replacement?
A picture of the hose on the engine can be seen here: PicPaste - 2016-08-20_1403-cBHwHSFH.png
Thank you!
Thank you Rob. I am replacing it because it broke off right at the nipple on the engine.
I purchased a piece of hose from AutoZone and put it on and all is well.
Thank you
Thank you everyone. I replaced it with a 7 inch piece of host with the same inside diameter. Cost me $1.19.
I was replacing it because the hose had broken at the nipple on the engine.
Thank you again.
Another option for any others that read this: cut an inch off the hose and reconnect it (assuming this hasn't been done 5 times leading to insufficient slack).
1 - 7 of 7 Posts
