This is a Frankenstein))
This was a LE5 which I converted to have a k04 turbo.
I quickly realized that I want more top end and more power in general, so I decided to upgrade to EFR6758 which will run on E85, and wanted a proper motor for reliability.
So the build is:
2.4L sand-casted bare block into which I installed forged pistons and rods, and new bearings. The crank, oil pump, and timing components came from the old block. The old block had 18k miles and was perfectly fine, with no issues.
I took the LE5 head ported it and installed new performance LE5 cams from ZZP.
Now I'm trying to put it back together, brake it in, and it will get a new tune after that.
My tuner said it should be runnable as is for brake-in.
I guess as long as I don't put into boost before that I'll be fine.
After gathering info from multiple sources I came up with the following plan:
1) So far I'm planning to start the motor with synthetic blend Valvoline 5w-30 (could not find regular oil). Run for 20 minutes and keep motor between 2k-3kRPM.
2) Drain oil, put in comp cams brake in oil
a) Drive 30 minutes while shifting low 3-3,5k rpm.
b) Now accelerate 2k-5k and let it engine brake. Repeat 6 times.
c) Switch to the regular driving mode for some time
d) Repeat b. Maybe do this cycle a few times as separate drives.
Drive 125 miles like that. Drain oil.
We are done here.
Put in Mobil-1 synthetic and add comp cams brake-in additive. Go to my tuner and hit it hard.
I drive about 1k miles a year in this car so next summer new oil change. I have a second bottle of comp cams brake in additive so each consecutive oil change will get half of it.
Sounds reasonable?
