1 - 19 of 19 Posts
I just joined and wanted to see if anyone is still here. I just bought a 2007 GXP and need a shop and/or member here that can fix the water pump. The car has 108,000 miles and it's in great condition. Thanks.
Gee, do you think it might be HELPFUL????? if you took the time to include your location in your Post? :brentil:
:agree:
Glad you came buy, bought the car and are looking for help in the right place, but SolNut is correct about knowing where ya all live.
You could add it to your user CP or mention it in the post.
Top Menu bar: User CP
Left Side: Edit Your Details
Scroll down to Location: Fill in where you live
at bottom: Save Changes
It'll save you from a lot of questions . . . .
-- OR --
put your location in the body of your message.
Thanks!
:thumbs:
Discussion Starter · #5 ·
I am in Tampa Bay, FL. Sorry for not including that bit. I am trying to edit my profile now, thanks.
Welcome to the forum and the Solstice permagrin crowd.
I'm here . . . and Welcome !
Discussion Starter · #12 ·
-- OR --
Thanks!
:thumbs:
Got it, thanks.
If you are going to have your pump swapped for you, make sure you read up on the issues associated with this activity.
The cam chain tensioner holding tool is a must to preclude issues with the assembly losing tension and eating itself.
Make sure your mechanic uses the generic Delco water pump as its about half the price of the Pontiac part and identical
Read up about issues with getting air bubbles in the coolant system and the resultant issues that many have had. There is a right way and a wrong way to deal with the coolant.
Good luck
Discussion Starter · #14 ·
Good luck
Thank you very much for the information. I have been searching high and low here in the Tampa Bay area for any independent shop that is familiar with the Solstice. I have come up empty so far. Naturally I am going to keep looking.
Welcome to the forum! Hang in a few more days and the Tampa crowd will catch up with you.
Our GXP is now in SC, but while it was down in FL we had pretty good service through Rivard Buick/GMC in Brandon (on Adamo Dr). They used to also be a Pontiac dealer. Did good work under our extended warranty, which is now expired. It's not an independent dealer, but they did pretty good work.
1 - 19 of 19 Posts
