1 - 16 of 16 Posts
In keeping within the forum rules, I can neither list a Manufacturer or Product Name. I can only provide that via PM. Staying within forum rules, I can describe the product. The fact that it won an award at the most recent SEMA show should be a clue. This Black Box currently supports C6 Corvettes, and allows you to view anthing from A/F Ratio's, knock retard to 0-60 and 1.4 mile times right on Instrument Cluster Message Center. It plugs directly into the obd II port and you're done. They plan on bringing this support to Camaros, CTS-V's, Cruzes, G8s, and Cobalts. They'd love to include the Kappa but they do not have a car for debug and verification. Without a car, they will not port the product to the Kappa as their reputation for delivering quality, bug free products to market is more important than the risk of delivering an unverified product.
The Solstice/Sky uses the same message center tech as the Cobalt and G8 but the Manufacturer of this piece of magic doesn't have access to a Solstice or Sky for Debug. To make things worse for myself, they're located in UTAH, 1700 miles away from me, so I cannot provide them a donor car for probably the 1 or 2 days they'll need for debug and then release . If you are a member or know of a member that lives in Utah, PLEASE,Send me a PM. It will take your DASH and give it LOGIC, hint!! Google.....DASH......LOGIC
Sounds like a great product, I'm also way to far from Utah. Other people post links to stuff.
That would be it. I've used their products for 3 years and you would find a more leading edge, customer oriented supplier. Before they released their Android version of dash command, I pestered them to the point that the decided I would be a greatI beta tester. I've never had a company Of this type be so responsive. If you really want to know what's going on in your lnf, their ScanXL Pro with the GM extended pid set is the best logger on the market, period. The DashLogic is a spinoff of all that tech.
Pretty cool idea! I have several OEM clusters I could send them, not sure if they can use just a cluster or if they need a complete vehicle...
I agree that the little message center is inadequate for displaying in depth data. It's also pretty unnecessary.
I have a cheap obd2 Bluetooth adapter and Torque on my mobile. I also have a nice Kuda mount for my phone. I just launch Torque and it displays all that info in any style or configuration I want, and it's not crammed into that message area.
I've always been under the impression that things like this can cause drivability issues, then again I could be misunderstanding how it works.
You mean this?: DashLogic - Palmer Performance Engineering, Inc.
Nice idea, but there's too much to display on one single readout as it is! I have an Ultragauge which also reports the 'extra' info, but also adds screen real-estate.
Yep there is an ap for that called:
" - command".
Android, windows or iOS
Whoa I just looked at it on the ITunes Store and it looks way cheaper than it was. Just $9.99 I think it was like $40+ In the past. Might need to hook this up with a Bluetooth obd2
Sent from AutoGuide.com App
I don't see anything that's not provided by the coupla dollar torque app for android.
Now, if they could have the professional specific pids that most manufacturers provide for a huge fee to mechanics, that would be good
for instance, and NOT in "gm specific" or other public library pids, there are hidden pids for abs performance, ecs performance and a host of othrs
Discussion Starter · #11 ·
Palmer Performance told me they needed a car as the product works through the obd ii port. I don't think they'd release a product which was only tested on a bench. They'd probably have to create a vehicle simulator on the bench with just a cluster but thanks for the offer.
Discussion Starter · #12 ·
I agree, all can be done on the android market. That said, the product has configurable alarms and it's a no hassle solution after the initial setup.
Discussion Starter · #13 ·
I've been running an obdlink bluetooth adapter and dashcommand on the street and track for three years without a hickup. I'm able to datalog and see virtual gauges, with warnings, far sooner than a MIL light. To me it's protection, and well worth it.
Discussion Starter · #14 ·
You must be running pure stock.
It may not be necessary if you're running a bone stock car. When you're running 30 lbs of boost, injecting water/meth and pulling the timing to the edge, you might want to know what's really going on.
my android app has configural alarms too though, I have to admit, setting them up is a pain
How does that change the fact that the tiny display area is completely inadequate for telling you what's going on?
Torque can give you real time information on all the things we've discussed in this thread, and all at once. AND it doesn't require lending a car to some company in Salt Lake City and hoping they make an inferior version of a $5 smartphone app.
This thing may be great on newer cars with larger and more sophisticated displays, but its totally pointless for a Solstice unless you don't have access to a smartphone.
1 - 16 of 16 Posts
