1 - 8 of 8 Posts
They said it couldn't be done - :lol:
New WERKSracing 2.4L LNF Stroker engine is now available!!!
After a couple in years in development we are proud to officially release our new 2.4L LNF Stroker engine! The goal behind this engine was to create a more broad midrange and usable power range for customers whether it is an automatic stock turbo street car to a big turbo race engine!
The WERKSracing 2.4L LNF Stroker long block engine assembly comes standard with the following services and components -
Cylinder Head -
WERKSracing high rpm single valve springs
WERKSracing MLS head gasket
WERKSracing high strength timing chain tensioner
ARP head stud kit
New GM valves, seals, direct injectors and high pressure fuel pump
New GM camshafts, cam gear phasers, cam solenoids and timing chain and guides
Short Block -
WERKSracing balanced 2.4L rotating assembly
WERKSracing/Wiseco Forged LNF turbo pistons
WERKSracing/Carillo custom Forged A-Beam connecting rods
New GM main and rod bearings
New GM oil pickup, water pump, seals and oil pump/front cover
New GM Timing chain and balance shaft guides, balance shafts, tensioner and balance shaft chain.
New oil filter
Customize and purchase your WERKSracing 2.4L LNF Stroker Engine Here - The Home of WERKSracing products!
Currently we have it added to our site as a long block option only but we also offer it as a short block as well, contact me for details and pricing on that option please.
The best LNF tuner I know of is up in the bay area, he can get it dialed in on 91 octane and I highly reccomend doing that, he is well worth the drive! I will give him your info and vice versa.
1 - 8 of 8 Posts
