I recently bought a manual 2007 GXP with 27k miles.
There are a few questions I had and maybe, some other experiences will help.
It is taking me some real time to perfect this clutch + transmission, compared to FBodies. At first I am either goosing it, or lunging it for the first week. Finally, I realize there is no reason in normal driving to push the clutch to the floor (unless you are parked and going into reverse). Not to mention, the first 1/3 of the stroke (from the floor) is totally useless in normal driving. However, that is only the start of the quirks of learning this particular car.
For some reason, 4th gear in this car, will occasionally miss if you don't slightly tend to the right. If you want to just flick gears with a few fingers, you better know this, for this vehicle anyway. Also, reverse has about a 50% success rate of going in on the first try, when first cranked and the oil is cold. I will try once and then if it won't go, let the clutch out and push it back in again, always goes in at that point.
What I want to know, is how can you improve these slight issues, on an otherwise great car? I was considering replacing the transmission and differential fluids, possibly flush + replace the clutch fluid too. If I am going to do all of that, I might as well flush the coolant too. I was thinking MT-90 for the trans. Any thoughts on other fluids mentioned, that would improve the experience?
Also, how normal are these for a manual GXP?
Thanks in advance,
Led
Thanks in advance,
Led
