1 - 2 of 2 Posts
New Hahn Turbo W/External Adjustable Wastegate Vid
Posted on YT 1/13/2017
NEW! Precision Turbo Upgrade, Solstice GXP/ Sky RedLine ? Hahn RaceCraft
DESCRIPTION
Precision turbos have been making a name for themselves for some years now, and in recent times they've really cranked up the development on turbos in the power ranges that Ecotec runs with. Hahn RaceCraft goes way back with Precision, as the owners of both companies (Bill and Harry) used to work with one another in each other's garages, way back in the 1980's as each was starting their respective businesses. They've both come a long way, and the combination of their talents is a proven winner.
With Precision's recent emphasis on this power segment, it was a natural for us to replace our aging Mitsubishi turbo line with these ultramodern Precision units. So we stepped up...big time! The concept here is already proven, as we've used this LNF mounting housing approach for years with the Mitsubishi S20G. Now it's just chock full of awesome, for not only have we added a sweet Precision external wastegate...we now offer the entire spectrum of Precision turbos in this system!
We retain the stock turbo manifold, for it's well-designed and proven to support higher power, both in terms of flow as well as in durability. We provide all the parts to mount the Precision turbo of your choice, making the entire installation a one-stop affair. From our innovative mounting housings, to every single bit of plumbing and hardware, you can have a Precision turbo and external wastegate mounted in an afternoon. You don't even have to remove your stock turbo manifold from the engine to install the Hahn solution.
The system also includes its own 3" 304 stainless steel downpipe. Starting with a super-strong thickwall elbow at the turbo outlet, the pipe transitions into mandrel-bent tube. The downpipe can be had one of two ways: either with the standard 4-bolt flange attaching it to the turbo, or with a trick-looking and easy to install 3" V-band connection to the turbo. Expertly crafted, with the best welds you'll see anywhere. If you'd like to add a second O2 sensor bung, click here.
You'll control your new Precision 39MM wastegate much like you do the stock turbo's internal wastegate actuator, using the PCM-directed solenoid. But you'll have nearly endless boost tuning options now, as we send along a box of different wastegate springs so that you can nail it, the way YOU want it to work. A dump pipe for the wastegate is also included.
Hahn RaceCraft's proven LNF turbo concept, now better than ever with Precision Turbos! Please let us know if you have a Precision turbo desire that is not reflected in our offerings here.
1 - 2 of 2 Posts
