My first look review for these tires, not a glowing report;
I don't know if these tires need to break in but grip in cornering is not even close to the oems, they let loose under very little gforce and the car does not feel like it's on rails like it did with the oems.
I have a particular 180 turn up a hill I practice whipping the rear wheels out, with these tires the entire car slides out under almost no excelleration and I don't have much time to steer with the rear end
There are pros to the tires though;
Very quite, very smooth running, when they do break free they do it much more gradually then the oem which stuck till they didn't so sliding was very hard to control, the nittos let you know they are about to let loose and sliding is more controllable
I'll come back once I get them in the rain, I suspect that's where they will shine but dry pavement is a total disappointment
I do not recommend these tires, maybe my opinion will change once I have a few thousand miles on them but given the choice between these and oem on dry pavement I'll take the original equipment, however when i do get these in the rain the improvement might make up the difference
I'll update this review as I learn more about the tire
