1 - 15 of 15 Posts
2006 Soltice # 110
Hi guys (and gals)! Can someone tell me the "normal" temp reading on the dash instrument panel. While riding around, I notice the temp fluctuates between 190-210. Had the antifreeze changed a couple of years ago at a GM dealer. 2006 Soltice with 29000 miles; number 110 in production. THX!
2006 Soltice # 110
THX! Was a little concerned with all the discussion regarding water pump problems.
That is normal. Mine runs around 190 when moving and will go to 210 at a stoplight.
Mine will run around 189 - 193 but can get as high as 216 then the fan comes on and drops down under 200. Mine is an 06 also.
2006 Soltice # 110
Discussion Starter · #8 ·
THANK ALL OF YOU FOR REPLYING!!!! WILL FEEL A LITTLE MORE RELAXED WHEN THE TEMP DOES GO A LITTLE ABOVE 200 DEGREES.
183 to 199 with new pump, thermo and coolant. Had been 205 to 216...so I think the lower temps are ,more normal. Also the rad fan ran on after shutdown but not any longer..
My 2008 GXP Turbo runs at 199-201 on a normal drive in town or highway. It will rise to 205 on a hot day in the city while stuck in traffic. The highest I have seen it go is 208 but quickly drops back to 199-201 as soon as I start driving again. My trusted mechanic says 210 is nothing to worry about. Hope this helps
2006 Soltice # 110
Discussion Starter · #11 ·
Thx! Very much appreciated!
2006 Soltice # 110
Discussion Starter · #12 ·
THX! Very much appreciated!
When the fan is running, in Florida, on 275 between St Pete and Bradenton (95 degree), normally 199-203, a bit more with AC........ when the fan controller died........ well over 250 when the light came on, then with the heater on high, 220. they tend to run hot.
1 - 15 of 15 Posts
