That's what I thought. If you have a 38mm offset, your total outward shift should be 17mm for the offset (55-38) and an additional 19mm for the wider rim for a total of 36mm or 1.42".19x8 front and 19x9.5 rear
Post some more photos of what it looks like from the rear. I personally like the wide stance at the rear. Makes the car look awesome IMHO. My rear tires stick out almost as much as yours (30mm or 1.2") and I have lowered the car 1.3" and I have had no rubbing at all.So LiquidPT is right perhaps new wheels is the only way.
or live with this setup for now? Seems like hell of alot of work to get that flush yikes!
Good advice. That calculator helped me significantly. You just punch in all your tire and wheel specs and it calculates centre line shift, backspace shift and more. It would have predicted your situation before you purchased the wheels and tires and would have saved you from the situation you are in now. The calculator was posted near the beginning of the thread.Did you use the offset calculator from that other thread to measure?
