1 - 12 of 12 Posts
I don't trust manuals, I trust people know what they're doing, and this form seems to be loaded with people who understand this car extremely well, for my 2008 GXP do you guys generally recommend 30 grade oil, or 40 grade? Maybe I'm not using the right words, but I do remember it's 30 or 40. I would think the turbo being a turbo one would go with the 30? If it helps I live in New York, hot summers, cold winters. Would one change the grade of the oil according to the season?
5w 30 Full synthetic many members use Mobile 1 I use Joe Gibbs Racing LS because it's made specifically for supercharged and turbo engines but again any name brand full synthetic such as Amsoil , Castrol , Valvoline etc. will be adequate do not use a blend
....I trust people know what they're doing...
This is a bad idea anywhere in life.
Owners Manual Page 5-17 said:
...Your vehicle’s engine requires a special oil meeting GM Standard GM4718M, such as Mobil 1® or equivalent. Oils meeting this standard may be identified as synthetic. However, not all synthetic oils will meet this GM standard. Look for and use only an oil that meets GM Standard GM4718M...As shown in the viscosity chart, SAE 5W-30 is best for your vehicle.These numbers on an oil container show its viscosity, or thickness. Do not use other viscosity oils...
I use Mobil 1 5W-30 and I believe most if not all others here use 5W-30 as well.
Talking oil with car guys is worse than talking religion or politics. Everybody has a favorite and you aren't gonna change anybody's mind about it.
The turbo needs full synthetic multi viscosity oil. Before synthetics a hot turbo would fry the oil and if shut down hot the oil would turn into black sludge that inhibits lubrication and the turbo dies.
Use oem recommended Mobil 1 5w30.
You should always trust the manual...they're written for a reason. Full synthetic only. 5w30.
I don't trust manuals, I trust people know what they're doing...
Just curious why you "don't trust manuals". Do you think that the engineers that designed the car don't know what they are doing?
If it was an Asian made product whose manual was translated from the Asian language to "English as she is spoken", then I would agree with you.
Discussion Starter #9
Because sometimes folks figure out things better than manufacturers through real life experience.
I a drummer besides an attorney and as a drummer we do things all the time manufacturers do not thing of or recommend etc, just for ex. Thanks
Got it all thanks guys, to all others above
The manufacturers are correct in specifying full synthetic and the 5/30 eight, but they standardize brand. You can use any oil that meets those specs, it doesn't have to be Mobil.
Just be careful - many manufacturers seem to fudge whether their oil is a full synthetic or blend. If you see the words 'semi' or 'blend' walk away.
1 - 12 of 12 Posts
