I know that this subject has been beaten to death but I'm at my wits end.
It started out as a "random misfire" at 76000 miles. At that time I changed spark plugs with info I got from this site. The code went to a cylinder # 3 misfire so I went to the coil packs, swapping them out to try to eliminate the bad one. No luck there so I bought a new coil pack and swapped it out with each cylinder -- no change. Then I looked for a cracked inter-cooler -- none found. I then did a compression test and found that cylinder #1 was a little soft ( 100 lbs vs 145 for #2,3 & 4) remember that # 3 is the one with the misfire. Every time I erase the code the light will stay out for about 100 miles then come on and stay on while the car runs fine.
No stumble , no limp mode 16+ lbs of boost in no tune mode.
I finally gave in and took it to a dealer for a diagnostic. Electrical system fine -- fuel system fine. I feel confident with the young gear head working on the car at the dealership. He thinks the next thing we should do is a leak-down test.
This Solstice has the BSR tune which I can bring back to OEM spects anytime. Any new Ideas
