So my 2007 GXP recently started overheating. It doesn't seem to be the usual overheat/no heat that I've seen on these forums. In fact I'm almost certain it has to do with the radiator fan but I'm open to more educated incite.
The details. I have a 50 mile round trip commute per day which is 95% freeway. It seems that as long as I'm moving at least 65 mph it will hold a steady 200 degrees. No blips or missteps there. However, as soon as traffic starts to back up or I hit one of the four traffic lights, it starts to heat up; fast. One light cycle can go from 200 to 230. Another light and its pull over time. My assumption is that my radiator fan is malfunctioning and not simulating air flow while I'm either moving slowly or stopped.
Now assuming I'm correct, where do I start? Is it a fuse or a relay? Is it the fan itself? Is there a simple diagnostic I can run or test the fan. No check engine light is on. Any help is greatly appreciated.
Final thoughts, yes the coolant is topped off and out of curiosity, I tried blasting my heat while it started to overheat and it blows just fine. I've also noticed that in the past, when turning my car off after a long Las Vegas desert heat commute, the fan would often still be running. It no longer does that.
Midehv
Midehv
