1 - 5 of 5 Posts
Just installed my rpm motorsports stage 2 tune, while I'm driving at wide open throttle around 23 psi if I hold that through 5200 rpms my boost drops to 0 and later gives me a p0106 cel, any ideas? I have cai, catless dp charge pipes, custom exhaust, and the new tune. I've checked the factory clamps and tightened then up but still no help...
Contact them (RPM). I would think there's a big red arrow with the word "Clue" on it, pointing at the tune you just added.
Is to bad people do not read (search) the forum 1st before adding a tune.
the cel appear while I was logging for the tuner... I did search the forum about the p0106 and from what I found was maybe a boost leak, but I checked all the clamps and seems like there all tight
I believe what Latin meant by his post was your choice of shop for your tune. Ultimately when you are done screwing around with this current joker you chose you might want to contact someone like Dave at DDM to straighten out your car. Hopefully you get to that point before serious engine damage. Good luck.
1 - 5 of 5 Posts
