I've read the threads relating to this code, but I still have questions. Is the solution more likely to be cleaning, or replacement of the sensor? Do I clean it then cross my fingers, or preventatively change it?
P0107 relates to the MAP sensor. I looked through the forum threads and did see some references to cleaning it, but as a question, not a recommendation. The MAF sensor is the one that sometimes benefits from cleaning.I've read the threads relating to this code, but I still have questions. Is the solution more likely to be cleaning, or replacement of the sensor? Do I clean it then cross my fingers, or preventatively change it?
My tune is by Trifecta. No crimping here, completely stock sensors.If you have the upgraded tune (GMPP) or the upgraded MAP sensors (held in by only 1 screw...your car may still have 2 screws, but only one ear on the sensor, which means it's a GMPP sensor), the dealers crimped the wires rather then solder them. If they are crimped, pull them apart one by one and solder them back together.
It is always good to find an easy solution.Turns out the sensor was just unplugged. I didn't unplug it, and no one else has been under the hood in three months.
This car is either cursed, or haunted. Since AFAIK, the previous owner is still alive, I'm voting for cursed.
Thinking that maybe the rough idle is what disconnected the sensor. It's that bad. Worse, actually.The code is cleared, and the idle is still garbage.
