Earlier today, I had a "pending" CEL pop up for P0300, P0301, P0302, P0303 all at once. Pending in that it hasn't actually made the light come on, but its going to soon (I pull codes with Torque every day). I have not noticed any performance issue and didn't feel the car misfire, which is what those codes indicate. The car did have a bit of a rough idle when it was warming up, so I guess that could have been it?
I drove the car around quite a bit today with the code up and it never moved from pending to the light actually coming on. So this evening I turned on the knock detector and did a couple hard accelerations to ~60mph. The knock detector indicated there were no detonations. However, the car then threw another "pending" code for P3500, which a search of google tells me I'm the first person ever to get this code.
As a bit of background, I recently had to get the timing chain replaced on the car as it was loose and rattling around. They also replaced the actuators and sprockets while they were in there, along with the water pump.
Thoughts? Could this all be the result of a mis-timed engine, or did I wind up with a lemon? I just put $2400 into this car in repairs and really hoped that would be the end of it for this year at least.
