Alright, so I asked about this on the Sky forums (since I drive a Sky) but they're too preoccupied with telling me I need psychiatric care or calling each other cranky old men to say anything constructive. I thought I'd ask over here where I usually find the answers to actual problems in my searching.
The story is that a few weeks ago my Sky got banged on a drive-up lift (of all things). Not on the fender, but much more annoyingly, on very-difficult-to-replace rocker panel below the driver door (and ever so slightly on the passenger side, to the point where I'm not worried about it at all). The metal got pressed in just next to the seam, and in one area, about a few cm long, it actually got scratched right down to the metal. I'd pretty mad at the idiot who let this happen and was driving the car up onto the lift, but unfortunately it was myself. :brentil:
Alright, well, I did a few things to try and rectify this. First, I wrapped a screw driver in cloth, and then bent the metal back down to the correct shape. Then, I cleaned out the scratch with some soapy water, dried it, and then applied 3 coats of touch-up paint. Finally, I looked under the lip (as if you were under the car on a lift, looking into the rocker panel) and noticed that in bending the metal back down, I managed to put a few gashes in whatever rust proofing material is on the chassis. Alright, I cleaned this with some alcohol, and sprayed a wax-based undercarriage protectant on there. The service manual says to use this X-121B product, but that is impossible to find in Germany, so I found what I thought was the most similar in composition and used that.
So, fine folks, I have a few lingering concerns:
1. Is the metal adequately protected from corrosion with just the touch-up paint? I think that it is not, and there should be primer on there, but I'm hesitant to sand it off and apply primer because the more I work this, the bigger the repair area becomes.
2. What is the stock chassis coated with? It doesn't seem to be a wax-based product, but it sure did mar easily. Is it galvanized (it looks awfully uniform)? Is there something better I can put on there (even though it would be a pain to remove the wax coating now)?
I appreciate any useful advice. You can't see this damage unless you are on your hands and knees, but like I said, my main concern is that I've damaged/improperly repaired the corrosion protection.
Here's a photo of the already touched up scratch, if it's of any value to you:
