1 - 3 of 3 Posts
Does anyone out there know what the part number is, and who the manufacturer is for the belt tensioner that is used for the serpentine belt for the DDM supercharger set up?
The bolt on the belt tensioner worked its way loose and the tensioner fell off and got a bit banged up. I was wondering if anyone has replaced it without having to go through DDM Works. Thanks for your help.
Vendor
The tensioner is a Dayco 89203, there is a slight modification that you need to do to it before mounting it. The Spring on it needs to be trimmed back just a little bit, otherwise it will touch the lower belt idler pulley. You will see when you go to install.
Hope that helps,
Dave
1 - 3 of 3 Posts
