I am working from a faulty memory since all of my notes are at home and I am at work, but from what I remember the PPS is a slave device, and only transmits data in response to a query from the SDM.
I am going to re-install my damaged PPS to see what the DTC is, because there is a specific code for a failed PPS and you are getting one for invalid or missing data. As I was doing my analysis I had a lot of invalid or missing data faults, and they were self-resetting in that they went away as soon as I installed a working PPS and did not require any reset with the Tech2. The failed PPS (broken like yours and most all of them) set what I assume was a different DTC because I was told that it did require a Tech2 reset. I was not present for the replacement, but I still have the failed part.
It is of course reasonable to assume that there could be different failure modes even if the cause is the same broken sensor trace.
