1 - 7 of 7 Posts
For some reason it seems like the passenger seat won't go as far back as the drivers side. Is there a trick i'm missing? or is this how the car is? I also noticed the passenger seat seems to be setup as if your sitting up higher.
Thanks,
Slim
My passenger seat is a bit higher than the driver's side. I think it's because my driver's seat cushion has sagged a bit over the years.
The leg room on the passenger side is shorter because of the fuse box....
:jm2c: On the side of the seatback there is a lever which allows adjustment.
Lean the seatback forward a bit and then the whole seat will move further back.
If you've already done that ~ then nevermind. :D
+1
Make sure the seat back is as far forward as it will go on its lever adjustment. The seat bottom should gain more travel on its track from there. As the seat back is leaned back, the seat bottom has to move forward.
Learned this the hard way after feeling like my knees were in my face the first three weeks in my Sky. Now, my 6'3" height fits pretty good... tho, still not as good as I did when I had my Fiero... :(
1 - 7 of 7 Posts
