Finally took a few photos. Sorry for the messy garage. It is due for a clean up and clean out this spring. Not to mention the PA weather hasn't been cooperating-so no outdoor shots yet. I am taking it to get the driver's seat cushion replaced and both inside door panels repaired (pulled from the foam arm rests). I have a few projects coming up. First, fixing the turn signal- it looks like I will need to remove all the trim pieces around the steering wheel to remove it and flip the spring? Secondly, replacing the drivers interior door handle. I did a "for now" repair to the chrome using a blow dryer and some Loctite. Saw a video where they used the cobalt door handle as a match, but replacing the pin looked to be difficult, plus they had to repair a plastic bit using a soldering iron. How are you all doing it? Any reference videos you can recommend?😊
