'Cane ended up with a troubled car which is sad to see. It happens. I have a '12 F150 I bought used and have had zero problems with it. My son bought a '15 used and has dumped about $3k into it.
The water pump appears to be an issue on the Solstices (both GXP and NA) but not other vehicles the engines have been used in. Some (including me) suspect it may because the engine was originally designed to be a transverse mount front wheel drive and there may be heat conditions due to this application.
Flushing the coolant and additives have been recommended by some members here to prevent the water pump seal from going. It's hard to prove if it actually works but an ounce of prevention is worth a pound of cure, right?
