1 - 7 of 7 Posts
I've searched Google with no luck. Who is currently making pillar gauge mounts? Looking for dual or triple.
Any other options available other than the pillar?
DDM Works is the only one that I know of. I take that back, I think Werks has one too for our cars. If you find one other then those, let me know, I'm getting ready to do a big mod on mine with IC, IC piping and HF Cat....and then a new turbo next summer.
I also have the DDM two gauge pillar.
I also found a gauge pod that fits behind the steering wheel. (-bay)
This pod houses the Interceptor gauge that plugs into the OBD2 port.
It shows me MPH on top and Engine heat on the bottom. But it also has two shift lights that come on when the revs hit you chosen RPM.
Discussion Starter · #5 ·
Any idea if I could fit a 60mm gauge? I understand that there would be some trimming required. Would want to avoid the outer rim of the gauge extending past a flush fit.....so to speak. The gauge I want to fit has an external diameter of 73mm.
I have both the pillar pod and the radio pod with hold 3 more gauges
1 - 7 of 7 Posts
