What should I do to the Mechanics that F*cked up my car?
  • Post a detailed Descrition of everything they messed up on every forum there is, including this one.
    Votes: 2 18.2%
  • Leave a terrible, detailed review everywhere on the internet: Google. Google Maps, BBB, Yelp, etc.
    Votes: 2 18.2%
  • Leave their name and number on bathroom walls "For a Terrible Mechanic - Call ###-####"
    Votes: 2 18.2%
  • File an insurance claim against them.
    Votes: 1 9.1%
  • Sh!T in a box, and mail it to them.
    Votes: 1 9.1%
  • Burn down their shop.
    Votes: 1 9.1%
  • Summon demons from the depths of Hades to torment their eternal souls.
    Votes: 2 18.2%
  • All of the Above
    Votes: 7 63.6%
21 - 40 of 49 Posts
Discussion Starter · #21 ·
Well, I have a trifecta tune en route from DDM. Is there anything I should know about installing it ?
Discussion Starter · #24 ·
Well...I've received the cable and sent them data...but I'm still waiting for my tune. :(
My experience of JohnWR is that he can be rather dry, like a good white wine.
that being said he is completely correct. Please follow the directions precisely. This is the one thing you do not want to rush.
You could (small chance but still) really make your car inoperable. You are rewriting a lot of engine critical data.
trust me, it will be worth the wait the first time you get to drive it :)
Well, was intended as a good natured chop busting but this being the internet, who knows what direction it will lead?
Discussion Starter · #28 ·
Well, a few drives after installing the Trifecta tune I was driving the car about 70 on the interstate and she had a reduction in power all of the sudden. The CEL blinked and then blinked again and stayed on. Now it's idling rough. I tried to check the OBD codes but my bluetooth OBD reader no longer works! I tried a friends and his didn't either! I checked the fuse and it was fine, but i changed it anyway - no change. Still no OBD reader working. :mad:
The only thing that did work was the Trifecta cable and software. Perhaps because it's externally powered?
Has anybody ever fixed this problem before?
Here's the codes.
p2626
p0300
p0301
p0303
p0304
p0302
p2297
so misfiring on all cylinders and some other goodies.
Did i just waste 600$ on this tune, or is there some other problem? What do you folks think?
Sounds like you need to call Trifecta and have them adjust the tune. Which they will do as part of your purchase.
p2626 - The P2626 code is a generic powertrain code related to computer circuit output issues. This code appears when the engine control module (ECM) has received a voltage signal from oxygen sensor number 1 pumping current trim circuit for bank 1 that is not within the accepted variances.
p0300 - P0300 indicates that two or more cylinders are experiencing misfires
p0301
- P0301 indicates that cylinder number 1 is experiencing misfires.
p0303 - P0303 indicates that cylinder number 3 is experiencing misfires.
p0304
- P0304 indicates that cylinder number 4 is experiencing misfires
p0302 - P0302 indicates that cylinder number 2 is experiencing misfires
p2297
- P2297 means that the oxygen sensor (O2) has out of range sensor performance when the vehicle is decelerating for bank 1 sensor 1
You may (if you haven’t already) specify the octane you are running it on…
Discussion Starter · #31 ·
I'm wondering if an O2 sensor is not working or was damaged when they installed the engine.
Also, the gas is 93 octane, ethanol free.
I've contacted DDM already. We'll see what they say.
Discussion Starter · #33 ·
Well, now my car has black smoke coming out of the exhaust.
Did this tune just destroy my new car engine?
I'd suggest you stop using this car until you have the tune sorted out. If there hasn't yet been serious damage you have been lucky.
A wrong tune could be underfueling your engine making it run lean. Running lean kills engines. It makes the combustion chamber temps become too high and you start melting pistons.
Discussion Starter · #35 ·
Yeah it's parked until I hear back from DDM. Which since it's been a week already....
Do people just hate our cars?
Every single time I have anything repaired or fixed on this car, either it it's fixed wrong, or someone damages it in some other way.
I think you have just been unlucky, especially with DDM. Their response is normally prompt and very helpful.
They do travel to events (like our own Annual Meet) occasionally, so they may be on the road. It is also possible that you picked the week Dave is on vacation.......
Exactly what I was gonna say.
That said the Kappas are not normal cars and as such they do need to be worked on by people that take a little bit of extra care. Even though they use bread-and-butter components in many areas, they also have very specific components and are built in an unusual way.
Discussion Starter · #38 ·
Thanks guys. I just need to find a good mechanic in Huntsville Alabama. Most of the smart mechanics are working on rockets around here. Lol
I finally heard back from DDM. They suggested I check the oxygen sensors and do some logging. Cool.
So I'm checking around the oxygen sensors and I find something..... unusual. There's something that appears to be not hooked up. Can you guys help me identify what this is and if should be connected to anything?
Automotive tire Motor vehicle Synthetic rubber Automotive design Tire
Automotive tire Hat Automotive fuel system Motor vehicle Safety glove
Automotive tire Bumper Motor vehicle Automotive wheel system Automotive exterior
Discussion Starter · #40 ·
Ok, thanks to this forum and pure luck doing google image searches I've discovered that sensor is the Camshaft position sensor. No, not the solenoids, and not the crankshaft position sensor. Anyway, I suppose it should be hooked up to something, right? Can anybody tell me where to locate the wire that the mechanics should have connected to this when they installed my new motor? 🤬
21 - 40 of 49 Posts
