1 - 20 of 27 Posts
Pontiac Solstice Fog Light LED Bulbs
Diode Dynamics' carries LED bulbs for replacement of your Pontiac Solstice fog lights, in all major sizes. This will make your fog lights a clean white color that closely matches factory HID lighting! Just simple plug and play, replace the bulb and you are good to go!
We carry the brightest, highest-quality bulbs on the market. These LED replacements are designed by our engineering team here in St. Louis, and every bulb carries with it a three-year limited warranty.
Brightness:
HP36: (210 lumens) Similar brightness to OEM bulbs
Please note that most LED fog lights are intended for cosmetic purposes only, and will not project light in the same way that the factory bulbs do. Your car will look great at night, but if you are looking for higher output, we strongly recommend using an HID conversion.
Bulb Design:
HP36: Full 360 degree illumination with 36 High-Power Samsung LEDs. Aluminum base for optimum heatsinking, and non-polar design for easy installation.
Fitment. All three bulbs use a quality inject-molded 880 terminal, with a full-size base connector and proper pin alignment, designed for exact replacement of your factory 880 bulb. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all modern vehicles.
Included in your order is TWO BULBS (to fit your Pontiac Solstice).
Diode Dynamics products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Click below for more info or to order:
Diode Dynamics: Fog Light LEDs for 2006-2009 Pontiac Solstice
If you have any questions, please don't hesitate to post, PM, email [email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Discussion Starter #2
Diode Dynamics: NEW! Stage Series Light Bars
Introducing STAGE SERIES LED lighting! Inspired by the needs of a professional rally driver, these light bars have been designed for maximum functionality, with compact size, cutting-edge TIR optics, and a useful beam pattern, all in a highly durable package.
-Advanced TIR (total internal reflection) optic
-Slim design, for easy mounting
-Available in driving or wide beam patterns
Our Stage Series Light bars are available in Amber as well! Here's the Driving and Wide output comparison shots!
Thank you,
Nick C.
Went down to shop in Dayton to purchase bulbs and there was no where to park! Maybe another day.
Went ahead and placed order online for fog lights, license plate and running lights.
Thanks....
Send us a PM to receive the free-shipping code
*U.S. members only
Thanks!
Nick C.
My 2007 Saturn Sky Redline has a H9 socket for the fog lights. Will your LED fog lights fit my car? If so I am ready to purchase.
Discussion Starter #9
Thanks.
That is really helpfull
Our email is: [email protected] and we also have live representatives on our website if you wish to chat about lighting upgrades for your Solstice. We are happy to help!
Thank you for asking! We don't offer an LED in the H9 bulb size, but we do have an HID conversion kit available if you are looking for more usable output.
Thank you,
Nick C.
Would like to see an image of what your trunk light looks like installed in the trunk of a solstice. I presently have your backup, license plate, side marker, and rear parking/turn signal bulbs. I would suggest removing the amber rear turn lights for the Solstice from your site, as the car uses dual filament bulbs for front and rear park/turn. Thus, only the red rear bulbs are possible.
Just put the bulbs in, but seem quite high quality. Question, do the backup light bulbs include capacitors? They glow at a very low level for awhile (maybe 5 minutes) after the car is turned off. Haven't yet checked to determine if this is from low current remaining in the wiring for awhile or due to capacitors or equivalent storage capacity in the bulbs.
Thanks!
Discussion Starter #18
Thanks!
We are still looking for a Solstice here in St. Louis to bring in for comparison photos & installation videos, but here's an example with our 194-direct bulb replacements in a trunk location:
This particular application has just one bulb in the trunk.
The backup LEDs do not include capacitors or resistors, and while it's possible some applications may stay extremely dimly lit due to resting current, it's on a vehicle by vehicle basis. It's not going to create any issues, drain the battery, etc, but if you add a small resistor it will take care of that.
Nick C.
Nick C.
I live just about 5 miles from your offices; if you send a PM, we can set up a meeting, so you can check out the Solstice. I have a few of your lamps in it already, and in other vehicles, including the backup lights. I have not noticed any afterglow with them, but I really wasn't looking, either.
1 - 20 of 27 Posts
