I bought this "seen better days" boomerang off a forum member as a spare for mods. It was scratched up in a number of places, plus had a paint-patch attempt in one ugly area, so I had already decided that I intended to repaint it (probably black).
Now, it's been discovered by others on the fora, that the boomerang factory finish doesn't work well with other paints (they wrinkle/lift/crackle). So as the weather was a bit warmer here today, and a precursor to new paint, I stripped the factory finish with an application of EasyOff oven cleaner. Sprayed it well (outside) and left it for a little over an hour, then cleaned off the softened paint with a toothbrush, rag and water (and rubber gloves!).
I had assumed the texture of the boomerang finish was simply the factory paint, but turns out that's only partially true. The plastic underneath the paint finish is smooth on the face, but textured on the top/side.
So without further ado... some photos so you can see for yourselves.
This is the whole thing, stripped, scrubbed, washed and dried (full size pic here: http://i949.photobucket.com/albums/ad339/TomatoSoup_GXP/Boomerang/Boomerang_zps56b0fc59.jpg~original ):
Then a closeup of the face, showing the smooth plastic:
Finally, a closeup of the texture in the top plastic :
Hope that provided a little entertainment going into the new year
-TS
-TS
