3501 - 3520 of 3542 Posts
Discussion Starter · #3,501 ·
One of the things I learned by R&Ring the bumper cover was that the crack was not caused by leaning on the car as I had initially thought. Instead it was due to stresses induced when the badly run body shop reinstalled the bumper and the new hood. What they did was get the center top bracket - where the center of the bumper cover bolts onto the structure under the center portion of the hood - misaligned. It is too low on the right side. This resulted in a twisting of the cover such that while it met the bottom inside corner of the right headlight, by the time it got to the outside corner of the headlight, there was a large gap. Then the hood outside the headlight was at a 15degree angle with the bumper cover. Rather than fix the problem correctly by realigning the center bracket to correct the angle of the cover, they tried to force the end of the bumper cover up to meet the now distant hood. This put a lot of tension stress on the cover in the area immediately under the outside corner of the headlight. Which is where the crack developed. When we pulled the cover and realigned things, a lot of this stress was removed and the issue is much better. I still need to pull the cover and move the center bracket about a quarter inch lower on the right end but that will come later.
Discussion Starter · #3,502 ·
PunisheR is going into Ride and Joy tint shop for the ceramic windshield film and a brow. And hopefull the text will be installed as well. The Hauler goes in Friday morning for the text. Hope to have both done in time for Garage Day on Saturday
Discussion Starter · #3,503 ·
The shipment arrived tonight. Color is near perfect match with the dash. Will install tomorrow.
Car Motor vehicle Vehicle Hood Automotive tire
Automotive lighting Motor vehicle Trunk Automotive tail & brake light Automotive exterior
Discussion Starter · #3,509 ·
Strobe came over and lent a hand with replacing the steering wheel in the PunisheR Hauler with one equipped with remote audio controls and heat.
We had a bitch of a time getting the stock wheel off. Took a lot of banging and hammering. The airbag took almost an hour to get off. One of the latches just would not release! But finally got it off. Then we had to pull the cover off the column so we could replace the clock spring! Always makes me nervous but it went very well. I drank coffee while Strobe did the swap. LOL
Now have to program the computer to recognize the steering wheel heater.
Discussion Starter · #3,510 ·
I rolled around under the Dragon for an hour and got the under hood green strobe light wired into the switch block in the trunk. Fun times. Lots of crawling and reaching and hooking and cutting but it now works. Finally. This pretty much completes the light install on the Dragon. Wheel lights, under hood green strobe and a pair of buttress hole green strobes. They work great. I am declaring success for now.
2008 Pontiac Solstice GXP
did you put in the steering wheel eater control module?
and you needed a steering wheel puller to get the wheel off. I could have lent you one.
Reactions: HHGadget
Discussion Starter · #3,512 ·
I bought one. We did get it off eventually. Thanks for the offer.
Discussion Starter · #3,513 ·
My how time flies
year
Just looked at the invoice for the custom paint of the PunisheR. 18 September 2008 14 years!
Total cost for color change, total dissassembly and custom graphics = $7,492.05
Description of Work Part Number Price Labor Paint Other
Replace Front Bumper cover 19120721 * 2.2 body 2.8 +Clearcoat (1.4) 1.4
Replace Hood 89025309 * 1.6 body 3.5
+Underside (1.8) +Clearcoat (1.8) 3.6
R&I Insulator 25801355 0.3 body
R&I Right Fender liner, Fender liner, 2.4 liter 25845786 0.3 body
R&I Left Fender liner, Fender liner, 2.4 liter 25845787 0.3 body
R&I Right Fender 15779404 0.8 body
R&I Left Fender 15779405 0.8 body
Refinish Right Fender 15779404 1.8
-Adjacent (0.2*) +Edging (0.5) +Clearcoat (0.7) 1.0
Refinish Left Fender 15779405 1.8
R&I Windshield, GM 15882117 2.5 body
R&I Upper frame 15822923 2.5 body
R&I Right Outer side frame 15952178 3.0 body
R&I Left Outer side frame 15952179 3.0 body
Refinish Right Outer side frame 15952178 1.2
-Adjacent (0.2*) +Clearcoat (0.4*) 0.2
Refinish Left Outer side frame 15952179 1.2
Refinish Upper frame 15822923 1.0
-Adjacent (0.2*) +Clearcoat (0.3*) 0.1
Repair Left Uniside 25880843 3.0* Struct 4.0
-Adjacent (0.2*) +Clearcoat (1.3) 1.1
Refinish Right Uniside 15928253 4.0
Replace Right Door shell 15859723 * 4.5 body 2.0
+Edging (0.5) +Interior Surface (0.5) +Clearcoat (1.3) 2.3
Replace Left Door shell 15909689 * 4.5 body 2.0
R&I Right Door Belt w'strip 15906527 0.3 body
R&I Left Door Belt w'strip 15906526 0.3 body
R&I Right Door Upper w'strip 15859648 0.2 body
R&I Left Door Upper w'strip 15859647 0.2 body
R&I Right Door w'strip 15859849 0.4 body
R&I Left Door w'strip 15859848 0.4 body
R&I Right Door Mirror outside, w/power 25881950 0.7 body
R&I Left Door Mirror outside, w/power 25881949 0.7 body
Refinish Right Door Mirror outside, w/power 25881950 1.0
Refinish Left Door Mirror outside, w/power 25881949 1.0
R&I Right Door glass, GM 15886662 Included
R&I Left Door glass, GM 15886661 Included
R&I Right Door Handle, outside 15823260 Included
R&I Left Door Handle, outside 15773795 Included
Refinish Right Door Handle, outside 15823260 Included
Refinish Left Door Handle, outside 15773795 Included
R&I Right Door Lock, w/power lock 15901301 Included
R&I Left Door Lock, w/power lock 15901300 Included
R&I Right Door trim panel, w/o power window, ebony 15952392 0.5 body
R&I Left Door trim panel, w/o power window, ebony 15952391 0.5 body
Refinish Both Quarter panel SEE FOOTNOTE 4.8
+Edging (0.6) +Lock Pillar (1.0) +Clearcoat (3.2*) 4.8
R&I Quarter Panel Fuel door 15929448 0.3 body
Refinish Quarter Panel Fuel door 15929448 0.3
-Adjacent (0.1*) +Clearcoat (0.1*)
R&I Front w'strip 25825371 0.4 body
Replace Trunk lid 89025246 * 1.2 body 2.0
+Underside (1.0) +Clearcoat (1.0) 2.0
Replace Rear Bumper cover 19120694 * 2.8 body 3.4
+Clearcoat (1.7) 1.7
R&I Header trim, gray 15254355 0.3 body
* Custom paint. Entire clear bra $650.00* nontaxed
* Hazardous Waste Disposal $7.50* nontaxed
* Cover car for paint $7.50* nontaxed
Discussion Starter · #3,515 ·
Winter project
Replace the LS1 water pump with a high flow pump.
Discussion Starter · #3,516 ·
Just received a pair of Sky RL headlights from a forum member. Thanks Nick.
They will go into the parts bin just in case.
I just noticed some weird stress cracks on Jazz' front bumper. You mentioned it's been off before. I wonder if it's the same thing. I'll try to get some photos in the next few days.
Discussion Starter · #3,519 ·
I have done some research about modifying the bracketry on the front of the LS. Dave told me that he delayed shipping the car because he wanted to install the pretty March Performance brackets and devices.
I looked into the possibility of installing a shorter water pump to bring the main pully back from the radiator without having to do major surgery on the whole shroud and front end. I sent the dimensions and pictures to a couple of experts in this area and they told me that they had their own kits that were basically the same dimensionally but they could not move anything back because it will not fit in the car.
I did some careful measurements and I have to agree. The forward spacing is pretty much fixed by the narrow engine bay in the front. Moving the plane of the serpentine belt to the rear is not possible because the AC and alternator are restrained by the front of the right head and the block.
So essentially they were forced to replace the stock mounting brackets with the after market due to packaging constraints.
I found this information educational.
Discussion Starter · #3,520 ·
KG wants to do surgery on the front of the car to slant the radiator and gain better airflow. We may end up doing that but I am going to try a couple of other things first to see if they help. More later. :)
