The two part mixed glue sets in less than a minute. The repair patch should be allowed to "set" for a couple of hours according to 3M
The two part mixed glue sets in less than a minute. The repair patch should be allowed to "set" for a couple of hours according to 3MInteresting work with a material i hadnt seen before Rob.
How long to cure until this stuff is sandable?
No, there isnt a lot of flex. The frame is very rigid and the backbone makes it even stiffer. The inner fenders have been failing since year one car one. The plastic is kind of brittle and they started failing very early. They went to "soft" fasteners because of the cracking. The dealers replaced thousands of them under warranty. Then most people kind of gave up and just accepted that they would crack and either ignored the issue or went to after market replacements.Do you think all the cracking is the result of the torque flex you generate, or the much under hood activity that you carry out on your special Solstice, or just age related. Are those factory fender liners.
That sucks.Caught a cold on Saturday. Worked from home per company rules until Wednesday. Then my lovely wife jammed a probe up my nose and the cold turned into covid. Sigh
double vaxed
boosted
had Omicron so some added immunity
Now covid 2022
So sorry to hear Rob. Hoping for a speedy recovery sir!Caught a cold on Saturday. Worked from home per company rules until Wednesday. Then my lovely wife jammed a probe up my nose and the cold turned into covid. Sigh
double vaxed
boosted
Now covid 2022
And you don't have worms. LolGet well soon.
I'm pretty sure wife and I have had the '22 version about a month ago. I had a very mild case and she was off her rocker for about 3 days (had to stay home only one full day) but we did not take tests. I made a deal with her that had the symptoms not receded in the 4th day she would be going to the lab for testing and if her test came positive I would get myself tested but it wasn't necessary.
I cannot prove it is related but I had taken ivermectine pills (1x6mg pill per 60~70lbs of body weight so took two) about a week before she fell ill and had much milder symptoms than her.
We both have had 3 shots and she had Omicron before the bosster while I had the July'20 strain that was making rounds in Brazil back then, before being vaxxed. All 3 doses Pfizer.
Yes, but he was feeling a little horse.And you don't have worms. Lol
