Punisher
800408 Views 3595 Replies 183 Participants Last post by  rob the elder
5
Punisher images
2016 update.
Added an index to this thread to make it easier to find subjects that have been covered when I need to find them. Or if you want to find them. :)
Its here
http://www.solsticeforum.com/forum/f62/punisher-65168/index152.html#post1765649
See less See more
3581 - 3596 of 3596 Posts
So after 15 years of the Rocky Mountain Solstice and Sky Club I finally decided it was time to make badges!
We have a pretty good turnover of new members and when we have events I know everyone but I forget that not everyone else knows everyone. If that makes sense. Then I feel like an idiot because I did not make introductions.
So, in light of the fact that we are coming ot the Nationals and it was time, I bought a badge printer and am making stinking badges for everyone! Then I don't have to remember anything!!! This is a sample
Automotive lighting Motor vehicle Hood Product Car
See less See more
Reactions: 3
Another successful club lunch. This time at the Punisher Garage. Several club members came over and we had a great morning/afternoon of sharing, eating and drinking. Was a relaxing, fun time. Thanks to all.
RTE
Reactions: 3
Checklist for reference
ItemDescription
1Pop open the key fobs to verify the integrity of the solder joint to the battery retainer
Exterior
1Verify operation of exterior lights
2Inspect body panels for fit, condition
3Check TPMS for function and tire pressure
Engine Bay
1Visually inspect engine bay for condition clean as necessary
2Verify brake fluid level and condition. DOT 3 change 3 years DOT 4 Change 2 years
3Visually inspect condition of all charge tube clamps.
4Check air cleaner filter element condition
5Inspect the PCV valve for proper operation and connection
6Check tightness of exhaust bolts, mounts
7Check tightness of turbo shield
8Inspect turbo oil lines
9Inspect oil fill level and condition (fuel contamination)
10Inspect / service battery terminals
11Inspect / service engine ground terminal
12Check all fluids. Verify mileage / life are within required values
13Inspect forward fuse box and terminals for condition
14Inspect hood / fender latches, lube as necessary
15Inspect electrical cables for condition
16Check condition of inner fenders
17Check ECM is properly mounted and condition of connectors
18Check radiator intake for blockage. Clean radiator with coil cleaner from Home Depot
19Check status of anti corrousion fuel treatment and add as required
20Check on age of belts and hoses
See less See more
  • Helpful
Reactions: 2
Cockpit and Top
1Check tightness of top when up and locked. Adjust as necessary (left and right)
2Query owner about wind noise. Adjust windows if necessary
3Check condition of door handles, tighten / repair if required
4Lubricate the sliding portion of top mechanism over the doors to preclude pinching.
5Inspect side slider and lube as necessary
6Visually inspect the slide plate over the doors for tightness and wear. Replace if necessary
7Check operation of the roof latch, tighten as necessary
8Visually inspect the windshield to top gasket. Looking for tears, holes etc. Lubricate
9Check operation of buttress latches, lubricate / adjust as necessary
10Verify proper operation of convertible top folding mechanism.
11Verify condition of rear window glass and defroster
12Treat all rubber seals with di-electric grease
13Pull the center console and check for cracks. Install support if required.
14Cycle both cupholders and check operation. Lube as necessary.
15Check operation of dash trunk release button.
16Pull the right carpet front and visually inspect BCM area
17Visually inspect BCM fuses.
18Cycle driver's seat height adjustment to verify operation. Lube as necessary.
19Check operation of hood release latch, lube as necessary
20Check dead pedal for condition
21Check door hinges for operation, service as necessary
22Verify condition of door body latches
23For vertical doors verify fit and adjust. Lubricate
Trunk
1Verify trunk latch operation
2Check trunk operation. Verify condition of torsion bars / hinges
3Check / service trunk lid hold down rubber feet.
4Visually inspect trunk pressure release valve
5Visually inspect flap cables for operation and condition. Adjust / Lube as necessary
6Visually inspect trunk cable assembly, connectors etc.
7Visually inspect and lube as necessary buttress latches
8Check trunk light for operation
9Check rear trunk drain area. Clean as necessary.
10Verify operation of trunk forward drains, left and right. Clean as necessary
Underside
1Inspect intercooler drain tube, check for presence of oil, water or contaminates
2Inspect radiator for blockage, clean as necessary.
3Inspect the front bumper and "chin" for scuffing or damage
4Visually inspect inner fenders for rubbing / wear inside rear wheel wells
5Inspect condition of wheel electrical connections
6Check break pads / disks for wear
7Visually inspect shocks for condition / leaks / operation
8Check wheel hub bolts (three per wheel) for proper torque (or if missing)
9Inspect the bottom attachment points for fenders and condition of fenders
10Visually inspect the differential for leaks and condition of mounts
11Verify condition of wheel bearing condition.
12Inspect exhaust system for condition and tightness
13Inspect condition of O2 sensor wiring
14Check / torque wheels
15Inspect tires for condition, wear
See less See more
  • Helpful
Reactions: 3
Having KAPPA training class graduate stickers made for the Nationals. When you attend the class, you get a sticker to put on your badge! So come to the class and get yours! If you attended a prior class you can get one too.
Font Rectangle Bottle Motor vehicle Automotive lighting
See less See more
  • Love
Reactions: 4
So I have been cogitating on how my trunk lid is fitting. I adjusted the hinges several times and got it close then decided to leave it for a few weeks. Then I got tired of looking in the mirror and seeing a gap on the left side of the lid. So I did two things. I loosened up the mounting bolts on the lid to hinge interface and improved the aligment and spacing, then I adjusted the latch on the trunk lid to tighten up the closed position against the trunk seal. I am much happier with the results. And its just another example of how much this cars body panels are adjustable.
Reactions: 2
I agree with the how much they are adjustable part......however I would add a qualifier in my case and that would be, 'if you know what you're doing'. The adjusting scares the heck out me, especially the hood. I am good with the fender panel.
  • Love
Reactions: 2
Took PunisheR out for a ride to the Club lunch. Was a lot of fun till the trip home. It started to RAIN! PunisheR got wet!
A rare occurrence. LOOLOLOL
  • Angry
  • Haha
  • Wow
Reactions: 4
I've aligned most (all?) of the body panels on my car at this point, since we had it apart for painting, and the amount of adjustments on this car is silly.
My then-wife was driving her 2007 Malibu (so, same era as our cars) when someone T-boned it and bent the passenger side rear door (fortunately somehow avoiding damaging the rocker panel or quarter panel). We found a salvage door in perfect condition, and planned on a day to swap doors and align it. We unbolted the old door, bolted the new one one, and it fit. Nothing to adjust. On the Kappa, the door hinges adjust both on the body and the door. Why could GM make the doors "just fit" on the Malibu but not the Solstice?
Reactions: 1
The solstice was on a limited production line and was designed to be hand assembled without the use of a lot of specialized tooling. The low production rate did not allow them to spend as much money as the much higher rate for the Malibu.
  • Helpful
Reactions: 3
3
This weekend i futzed around with the prototype split hard top attempting to get it to fit and pulled out my blower motor control module…
Then ordered the replacement dorman module and pigtail harness
Wood Motor vehicle Rectangle Grass Linens
Tire Wheel Car Vehicle Hood
Toy Bumper Automotive exterior Automotive wheel system Font
See less See more
Reactions: 2
Thanks to your recommendation I bought a couple of spare kits.
Reactions: 1
I ordered a Banks iDash gauge. I have one in the truck and like it. I am going to see if I can make it fit in the gas gauge area of the gauge cluster. Up front just behind the bezel. I ordered a spare bezel to experiment with. I did a dry fit and it looks like with some trimming here and there I can get it to fit behind the bezel. According to their website, it will display Fuel Tank Level in %. It also displays things like ambient air temp (yes indeed), intake air temp, Pressure altitude, engine load, horspower in %. fun stuff, But the main reason is to get a better fuel gauge.
Banks iDash SuperGauge and iDash DataMonster (bankspower.com)
Reactions: 2
Oh man i dont know how i posted the blower thing in your thread Rob.
Apologies!
PS i went on your idash link and was messing about and saw it only “supports” the 2.4l.
i assume thats just lazy data-basing on their part as i cant imagine it wouldnt work with either motor / ECM module?
Reactions: 1
10
Mounting the iDash. It fits well with a little trimming of the tunnel and the front bezel. I ran a test with a spare set. Good result.
See less See more
Reactions: 1
Apologies!
It should cover both cars but we will give it a test.
Reactions: 1
