A little research
OTC - TPMS Reset Tool
Part Number: 3834
Line: OTC
1 year warranty on repair
• UPC: 731413557323
• Tire Pressure Monitoring System Reset Tool
Detailed Description
The OTC's TPR is a fast and simple to use stand alone TPMS activation tool
•Works on all known TPMS sensors through 2009.
•Bright graphic display and simple navigation buttons enable vehicle selection for fast activation.
•Automatically adjusts activation output power to eliminate cross activation of near sensors.
•Easily Updated with a wireless connection to the Genisys scan tool when new software is installed on the Genisys.
Why my current TPMS Tool cannot trigger / activate / reset some sensors ?
That is because your TPMS Triggerring tool is not compatible with that sensor. In other word, it does not carry the TPMS protocole required to communicate with that specific sensor.
TPMS sensors on the market are manufactured by different companies.
Those companies did not meet to agree on one TPMS wireless protocole. As a result, there are lots of different TPMS sensor protocoles and this number keeps growing as new sensors are coming to the market every day.
So if you purchased a TPMS tool a while ago, you will soon start seeing vehicles from which you cannot trigger the TPMS sensors unless your TPMS Tool can be upgraded over the internet with new TPMS sensors protocoles.
This is why you should make sure that your TPMS Tool can be upgradable easilly through the internet, or else become obsolete quickly.
Why are all TPMS sensors using different protocoles and why ATEQ has access to those protocoles ?
That is because TPMS sensor manufacturers did not agree on one protocole. On top of that, those TPMS manufacturers tend to keep their protocoles secret.
Fortunetely they are always obliged to release those protocoles to car manufacturers if they wish that those manufacturers mount their product onto their cars.
And that is where ATEQ has a real advantage over other TPMS tool manufacturers. ATEQ also equips car assembly lines with TPMS activating antenas and Tools. So the car manufacturers give us the TPMS protocoles which we can then implement into our online TPMS protocole database years before they actually hit the market.
So when you purchase an ATEQ upgradable TPMS tool such as the ATEQ VT15, the ATEQ VT30 or the ATEQ VT55 OBDII, your tool will always be compatible with upcoming sensors.
Why prefer a "Universal" TPMS tool over a conventional one ?
So you can trigger all TPMS sensors on the market as opposed to just a few.
Not only do we advise you to get a universal TPMS activating devise such as all the devises ATEQ sells, but we also recommend you to get an upgradable one, so you can keep it "Universal" as new sensors and protocoles come to the market.
