1 - 2 of 2 Posts
A couple of questions about the Monsoon Radio system. When you set the time you are also asked for the date. However, I can't find anything about when or how to get the date to display? Only the Time is on the display along with the xm/fm or cd info. Also, I hear no difference in the volume when I change the speed compensated from off to low, med, or high. I thought the volume should increas quite a bit when set to high? How loud should the volume increase? Because I can't hear any change at all. Thanks for any info.
1 - 2 of 2 Posts
