21 - 23 of 23 Posts
Just confirming the wiring was bang on from JohnWR. Always dubious grounding a wire that says 10v on the description :unsure:, however it was correct. Thanks to all, especially John. I now have to get the rear camera wiring through, but that's another day and then rebuild everything back up !
Glad it worked. I agree about the grounding concern, which is why I posted the schematic to show that the circuit is isolated and the 10V originates in the OE radio.
Camera wiring is not going to be fun. I have delayed doing mine for months. Maybe this spring.
It's really not that bad. Just pop a sill and 3/4 panel and feed the wire into the trunk between the carpet liner and the molded plastic trunk tub. I drilled a small hole in the plastic tub to feed the wire from there to the license plate area, though it might be possible to go around the outside of the tub.
21 - 23 of 23 Posts
