1 - 4 of 4 Posts
Only happens when cold and at high rpm's below 180 f 3000 rpm.Can't get to happen when at operating temp above 180 f. :cuss::cryin:
Does it seem to bog when it happens? How many miles on it? Ever changed your spark plugs? I'd try that first.....regardless of miles. Are you tuned?
Don't have a tune, spark plugs changed 20,000 ml ago, bad stumble not really a bog. Car has 110,000 ml.
hmmmm....this could be anything from plugs to your hpfp. It actually could be the hpfp with that many miles. Have you run the car out of gas lately? Without actually getting another code or data logging a run when it happens, it's almost impossible. Do you have a way of data logging so that we can look at a log? (DashCommand or Torque app?) Any one else wanna chime in here????
http://www.solsticeforum.com/forum/f43/engine-code-p0300-34020/
http://www.solsticeforum.com/forum/f59/misfire-help-needed-68124/
1 - 4 of 4 Posts
