1 - 10 of 10 Posts
· Administrator
I Recently purchased a 2006 Pontiac Solstice and the rear hatch will not stay up? Where are the shocks or is there just a rod to hold the hatch up? Need help?
The trunk lid is held up by two torsion bars that will fatigue and get weak, as yours have.
Replacement of the bars requires removal of the rear bumper cover, and assumes that you can find new bars. Two alternatives are the installation of a coil spring, and the installation of a gas strut assembly. The spring is inexpensive and easy, but I did not find it to be as good a solution as others have. The gas strut assembly is made in Germany, elegant, relatively simple to install, but somewhat expensive. Discussions of all three options can be found on the forum with a search, or someone may re-post the information here.
Just FYI for the gas strut installation on a 2006 Solstice is a bit more complicated than on a 2007-09 due to sheet metal changes they made for making the Sky and Opal GT models. The strut is almost a straight bolt in on a 2007-09 Solstice, but requires a small amount of steel to be removed on a 2006. But it is not that difficult and does work well on a 2006. I have done it to mine.
Reactions: Docksider77
'06 Solstice Base
I've done it to my 2006 as well.
Can you send me a picture of yours please
Worth the cost, and adjusted properly, can make opening the trunk lid appear to be power operated. Begin with the next to highest setting or you'll be regretting having to reset the installation. One of the best mods I first did to my car. The company in Germany is top notch and very good customer service. Only having to deal with DSL international shipping and once the package hits the US can slow down a timely delivery even before COVID. Be patient. It is well worth the wait as well as the money. If you don't find out the ordering information PM me and I'll get you there. Old thing of "if it works, use it".
Richard Snipes
The trunk lid is held up by two torsion bars that will fatigue and get weak, as yours have. Replacement of the bars requires removal of the rear bumper cover, and assumes that you can find new bars. Two alternatives are the installation of a coil spring, and the installation of a gas strut assembly. The spring is inexpensive and easy, but I did not find it to be as good a solution as others have. The gas strut assembly is made in Germany, elegant, relatively simple to install, but somewhat expensive. Discussions of all three options can be found on the forum with a search, or someone may re-post the information here.
Hi. That information was very useful and thanks. I have a 2006 Solstice I just purchased. I have a question maybe you could answer for me, the rear hatch does not pop up when I press the rear hatch release button in the glove box. When it is released the hatch rubs against the body at the hinge side. It looks like the hatch should come up and then open ? Thanks in advance.
This is a separate rear deck lid issue than the fatigued torsion bars.
Yours is likely out of alignment or your rear bumper cover is, or both of them are as they should never touch at any point of travel.
Search the forum for “body panel alignment”
1 - 10 of 10 Posts
