did you check at https:// www. world parts direct. com/ ?Anyone know of or recommend good aftermarket rear springs for the base model? No lowering, same ride quality. OEM #15280026 are discontinued. Need base model, non-sport suspension type springs.
Thanks for any help.
Frank
Discontinued.did you check at https:// www. world parts direct. com/ ?
I’ve got 21000 on mine. My car leans 1/2”- 3/4” on the left rear side. Becoming noticeable. Anticipating replacing rear shocks and springs. Still not absolutely sure why this is happening or how common. A few others I’ve spoke to also have noticed this on theirs. May be from driver weight over time. Trying to pin point issue. Wanted to price out new components then discovered discontinued.PM me if interested I should still have my OEM ones that I replaced with Eibachs at 26000 miles I'll check today .
Just how heavy is the driver? Mine have 90k and 108k with no spring sag. Spring failure as 21k is extremely odd and I would look for other possible causes.I’ve got 21000 on mine. My car leans 1/2”- 3/4” on the left rear side. Becoming noticeable. Anticipating replacing rear shocks and springs. Still not absolutely sure why this is happening or how common. A few others I’ve spoke to also have noticed this on theirs. May be from driver weight over time. Trying to pin point issue. Wanted to price out new compliments then discovered discontinued.
A few years ago with balance. Would an alignment effect height?Whens the last time youve had an alignment?
Agreed. Hood alignment is probably the culprit in the front. Rechecked rear. Measured from top of OEM wheel to wheel arch, leaving out any tire descrepancy. Left rear at 5 1/2". Right side at 5 7/8" . Level surface in a garage.Realize that only one corner can't be low. If it's tilted to the left, it should show on the front and rear. Although, the hood alignment can affect the front, making the front a bit less accurate.
Were you parked on a verified flat surface? Could easily be an inch of difference in the surface and you'd never see it.
It'd be a bit of work, but you could try swapping the springs right to left. You'd get a good look at things while doing it too. Or do you know someone with scales? Getting corner weights might clue you in to bad spring or other issues.
Also a Sky here.Mine is a Sky, and I don't know how that affects the fender opening, but at 108k miles I have 28 at both rears, 27-7/8 at driver front, and 27-3/4 at passenger front.
The parking lot is asphalt and reasonably, but not perfectly, flat.
I am going to disagree here. Ride height can be checked by rolling or driving the car onto a flat surface, with the caveat that the accuracy of measurement depends on the flatness of the surface. I have a concrete garage floor that was finished specifically to allow the suspension setup of the cars we were racing when I built the house. It is not quite as accurate as an alignment rack, but it is well within the limits of any measurement being done with a scale or measuring tape.The only proper way to check the ride height is on an alignment rack. Th suspension has to be unloaded and the loaded again. this is done by jacking the car up off it's wheels and then letting it back down, the tires have to sit on something that is able to float so they unload when the car gets set back down. ..........
