1 - 4 of 4 Posts
Hi, i did a little bit of research on this topic but i did not find a definite answer. What is the difference between the rear z0k sway bar and the rear gxp sway bar? Thank you for your help!
Note that Z0K means different things depending on the model you have.
The GXP Z0K bar is stiffer than the GXP standard bar.
The NA Z0K bar is the same as the GXP standard bar (and stiffer than the NA standard bar).
Full (and exacting) details may be found here: http://www.solsticeforum.com/forum/f42/suspension-packages-usage-58501/
1 - 4 of 4 Posts
