Thank you sir! I first learned that trick from my dad years ago. Recently I’ve been using a stethoscope with just an open tube on the end. You can really hear with that thing. Thanks for reminding me. I’ll check if the sound is coming from the timing chain area.You probably obviously already know this but… (and apologies)
After advice from the forum (screwdriver) I used a drumstick pressed into my ear and the other end on the various suspect parts.
I definitely was able to ascertain what noise was coming from where on my car really quickly. Was actually fascinating to hear all that engine noise get a little more isolated with the drumstick in my ear.
Make sure you aren’t wearing any hanging items like a necklace or hoody pull strings as you are really going to want to get in there.
love your work love your channel!
I use an actual "listening rod" which is a three-foot-long steel rod about an eighth of an inch in diameter with a three quarter inch brass ball at one end. the steel conducts sound exceptionally well, and the length keeps you a bit more out of harm's way. You do still have to be careful to not stick it into anything moving, of course.You probably obviously already know this but… (and apologies)
At 3ft that’s sounds like a cane or a walking stick.I use an actual "listening rod" which is a three-foot-long steel rod about an eighth of an inch in diameter with a three quarter inch brass ball at one end. the steel conducts sound exceptionally well, and the length keeps you a bit more out of harm's way. You do still have to be careful to not stick it into anything moving, of course.
Long enough for a cane, but definitely not stiff enough.At 3ft that’s sounds like a cane or a walking stick.
Regardless it really is amazing utilizing dense material to conduct sound.
However I am generally easily fascinated so I suppose the bay is low for me.
Keep us posted and good luck.Thanks everybody for your input. I’m going to tear into this as soon as I get the current project out of the shop. Hopefully next week.
Slapping da Bass made me think of Davie504.Finally got to hear this on proper speakers. Sure does sound like the chain "slappin da bass" so to speak.
I was thinking Paul Rudd’s in character in “I Love You Man” obsession with Geddy Lee of Rush but the above will suffice.Slapping da Bass made me think of Davie504.
Start watching at 1:14 of this video:
I have to admit, if my timing set up sounded like that................ well, that'd just be interesting.
Hey Mark, I'd really appreciate it if you would video the repair from start to finish, and I'm sure a lot of others Kappa owners would too. TIAThanks everybody for your input. I’m going to tear into this as soon as I get the current project out of the shop. Hopefully next week.
I got that reference!Finally got to hear this on proper speakers. Sure does sound like the chain "slappin da bass" so to speak.
Will do! We’ll probably put it in our tutorial playlist.Hey Mark, I'd really appreciate it if you would video the repair from start to finish, and I'm sure a lot of others Kappa owners would too. TIA
