1 - 12 of 12 Posts
My Solstice sticker in the threshold of my door is peeling up. Can I get a replacement.
I kinda remember reading this one in the past, and I think you have to buy the whole replacement part (not just the sticker) ...others will chime in and help you better...windrestrictor makes some really nice ones that could fit there too :)
If you are talking about the sill plate, then JesseB is perfectly correct. Almost impossible to repair (since you'll kink the metal strip if you try to take it off) and only available as one piece with the plastic molding. Plenty of threads and posts on this in the forum if you search.
I have the backlit Windrestrictor overlay. Love it.
Part numbers: 25774447 & 25774448 (LH & RH respectively)
...TS I was wondering on the backlit ones as well...do you take the chrome stock one off before you put the windrestrictors overlays on?
The WR ones go over the existing plastic sill piece. If your aluminum strip (if you have one) is good, it goes over that. If the strip is coming off, then better to remove the strip completely before attaching the WR overlay.
one of mine is peeling up and the plan is to heat it with the heat gun to see if I can remove it without causing any creases and then glue it back down.
Discussion Starter · #9 ·
JesseB How or whom do I order that from? Thanks
Oh yea Good Grief.....
I tried this on the Dragon. My experience was that by the time I got the glue hot enough to pry the aluminum part off successfully, the plastic was deforming. I went with unlit WR door sills as the best long term solution.
Get a piece of clear bra material a little bigger than the sticker and install it over top. Had that issue with another car and the clear bra material worked like a charm. Never had an issue again.
1 - 12 of 12 Posts
