Quick recap. I’ve been battling a misfire condition in all 4 cylinders for a thousand miles or so. There are no indications of a misfire except the CEL is on. I’ve replaced plugs, ran fuel system cleaner, changed fuel suppliers, and even the battery for something else not related. After the fuel cleaner and plugs it was off for 500-750 miles maybe. Before this issue came about I bounced the motor off the rev limiter and it immediately went into limp mode. The code was low fuel pressure or something like that and the HPFP was sounding very loud and erratic. I drive it home in limp mode(12-15 miles). About 2 miles from home it cleared itself up and went out of limp mode and the HPFP sounded normal. No issues for a few hundred miles then this issue came up. It has gone into limp mode one more time when I hit a slick spot taking off in first gear and the pump did the same thing again. This time it cleared up after 6-7 miles of driving.
I’m suspecting the HPFP could be the culprit for the reasons above by thinking I may have damaged it somehow. The other issue I’m having once in awhile is a stumble taking off from a stop. I’ll give it gas and it will stumble for a second or two or it will feel like I’m not giving it gas. The rpm’s will also drop to 450-500 while idling every now and then. The other issue I have once in awhile is after it sits for a couple days it will take 2-3 seconds of cranking before it fires but not every time it sits this long. Perhaps the O ring inside is cracked or something in the pump itself isn’t working correctly. I never had any issues until after the limp mode incident. The guy at the auto parts who ran the code says check wiring harness for injectors I believe. I’m not sure what I would be looking for and have only looked for a few minutes and couldn’t see anything from the norm. Any other suggestions? Thanks
