1 - 10 of 10 Posts
My driver side speaker cover is cracked. Where do I get a new one. And do I have to remove speaker to replace?
Good grief. Thanks
Discussion Starter · #5 ·
How much are door panels and where do you get them?
Thanks!
Expensive & from a dealer (or online parts place/dealer)
Find them on eBay. I bought mine from there. You can find them at a decent price. Or switch to sky panels. They look much better.
This seems to be a common problem, I have the same issue. I was thinking of removing the door panel, cutting the speaker grill out and replacing it with an after merket one such as this:
I've used those for my 12in woofers back in the day. the only way to install them is to pull the rubber ring back and shoot a screw thru the door panel and if you use a bolt that holds the speaker, you will see a dimple where the screws are. I'm planning on changing mine out and will use whatever grill comes with the speaker.
1 - 10 of 10 Posts
