2008 Solstice right rear brake and turn signal is not working and the front right turn flashes fast. The RR bulb is good, and I also tried a new one just to confirm it. I also tested the contacts and the wires to the bulb socket with a test light and there is not any flashing 12v. on the black wire that runs the turn and brake filament of the bulb, so I know it is not a bad bulb or socket contact. From what I can tell, the turn and brake feed comes from the BCM, so can anyone tell me if there are any known common problems with this? If not, any suggestions? The car has never been wrecked so there shouldn't be any wiring that has been repaired or damaged.
Thanks,
Jeff
Thanks,
Jeff
