Hey guys,
So I just recently started having this problem with my turbo LE5 2006 Solstice where when I'm cruising, if I let off the throttle and either depress the clutch or put the car in neutral, the rpms will hang up around 1500 for a few seconds, then 1100 for a few seconds, before finally returning to idle. It seems like it doesn't even return to idle until the vehicle is completely stopped. So far, I've cleaned the throttle body, cleaned the MAF, reset the fuel trim (with a scan tool), and quickly checked for vac leaks with a can of starting fluid to no avail. Does anyone have any ideas?
Sent from AutoGuide.com App
