1 - 2 of 2 Posts
2008 Pontiac Solstice GXP
I compiled a database of 18,398 GM RPO codes. I have not separated the list by what codes are available for what year and model and I will probably not do that because it would be a HUGE headache to do. There may be some that are missing and I will fill in those blanks as I come across them.
I can however search the database for specific codes or from a list of codes and it will return the matching RPO's with descriptions. If you want to know what options your car has key out the RPO codes in a post and I will give you the results. If you want a list of codes done it needs to be one line of RPO codes separated by a space. It does not matter if the RPO codes are uppercase or lower case.
example:
Code:
YTA NHT QIQ XNP 1K5 D6G XUF WK1 Y52 20 UVH C9R VL8 QHI B39 8BF UWR XFG ERJ R41 6C9 Y53 GTH ZY0 5IH RUR 9JC 9H8 BVN ELL
and what I would respond with
Code:
YTA: TIRE REAR 225/70R19.5/F BW R/ST TL OOR
NHT: PERFORMANCE PACKAGE ENHANCED TOWING
QIQ: TIRE ALL P205/60R15 WOL R/PE ST TL AL2 90S
QIQ: TIRE ALL 225/70R16 BW PE/ST TL ALS
XNP: TIRE FRONT 8.00R19.5/D BL R/ST ST TL HWY MICHELIN (14065888)
1K5: TRANSMISSION LOW GEAR BLOCKOUT
D6G: GEAR SPEEDO DRIVEN (25522487)
XUF: TIRE FRONT 225/60R16-98S BW TL ALS
WK1: APPEARANCE PACKAGE,PONTIAC 'SUN AND SOUND PLUS'
Y52: SALES PACKAGE CADILLAC, INTERNATIONAL UTILITY
20: RATIO CODE 5.63
20: MOLDING DOOR INTR GRAPHITE SILVER METALIC 558Q
UVH: EQUIPMENT DRIVER INFO DISPLAY LANGUAGE (PORTUGUESE)
UVH: VISION 360 VIEW, MONO
C9R: SPECIAL PAINT OPTION (AUTUMN MAPLE MET)
VL8: WHEEL WRENCH HANDLE,DISC WHEEL,BS TYPE
QHI: TIRE ALL 195/65R15 BW R/ST TL ALS 91H
B39: CARPET,LOAD FLOOR
8BF: COMPONENT RR LH - COMPUTER SEL SUSP
UWR: RADIO AM/FM STEREO, SEEK/SCAN, MULTI CD, MP3, ETR, I/P AUTO TONE
XFG: TIRE FRONT P285/30ZR19 BW TL HW4 EMT
ERJ: EQUIPMENT CARGO, TRIM COMPARTMENT PKG, ALUMINUM
R41: WHEEL 20 X 8 FRT & 20 X 9 RR, J, ALUMINUM, DESIGN 3
6C9: CONDUIT-TWO WAY RADIO CONTROL CABLE
6C9: COMPONENT FRT LH COMPUTER SEL SUSP (6C9)
Y53: SALES PACKAGE TECHNOLOGY DRIVER AWARENESS
GTH: PRIMARY COLOR EXTERIOR, YELLOW (5456)
ZY0: WARRANTY 50, 000 KM, 2 YEARS
5IH: COLOR SPECIAL PAINT #8
RUR: WHEEL 19 X 10.0, J, FRT & 20 X 12.0, J, RR, ALUMINUM, DESIGN 1
9JC: COMPONENT RR RH COMPUTER SEL SUSP (9JC)
9H8: LAMP SYSTEM DAYTIME RUNNING, AUXILIARY
BVN: STEPS ASSIST, SIDE, REMOVABLE
ELL: PLANT CODE ELLESMERE PORT, ENGLAND
If you are familiar with the Python programming language and want a copy of the script shoot me a PM.
For those of you that want to know exactly what options your car has give me your list of RPO codes.
Reactions: agent008
I will oblige...
AU0 AU3 A31 A50 B32 C60 D48 FE2 FE9 GW1 IP2
JL9 KG7 K34 LE5 MA5 MM5 NT9 N34 N87 PCQ QFX
R6P R8K R9N SLM T96 UK3 UQ3 US6 US9 U2K U68
VY7 V73 WIL ZQ2 ZQ3 1SA1ISZ 19I 19T 192 74U
Thanks!
1 - 2 of 2 Posts
