Okay, so the the other day I noticed in my 08' GXP when driving at low speeds of less then 20mph I can hear a slight clunk/pop noise coming from the rear when I let off the gas padel. NOT the clutch. I'm also getting a rubbing or scrapping noise coming from the driver's side rear wheel.
Here lies my big problem, I'm not sure if it's only the diff that is making both of the noises or if the two are coming from two different areas. The scrapping sounds more like a bad wheel bearing. But would that cause the clunking noise too?
Last month my car was hit on that same side by some idiot changing lanes. The impact was on the rear fender above the wheel and he also hit the wheel it's self causing damage to the rim. I had it all fixed and have had the car back now for about 2 weeks. Now I am hearing these new noises and am trying to figure out if they missed a bad wheel bearing and only replaced the wheel. They did do a new alignment and ballanced the wheel. At first no problems, now I just started noticing this on Saturday. Should I start wit ta diff/fliud change and then go from there? I can always bring it back to the repair shop and tell them about the bearing, but I'm not sure if both noises are coming from the same area or not? Can anyone tell me when it is the proper time to replace the diff. fluid? Car has 29K miles on it.
