The OE Intercooler (IC) are a weak point. They can split at anything over 20psi. Many have had this issue. If the IC does hold to 24psi, then the turbo is too small and just becomes a heat pump after 24psi with a factory IC. And then that introduces knock which the LNF does not like, nor does it last too long with knock. Also the turbo can usually only push no more then 24psi as the seals just won't hold. I'm dyno tuned and pushing 24psi with the OE IC. The tuner programmed my fan to come on 100% at 190 degrees so that it would cool the IC because running it on a dyno produced too much knock with all the heat.
If you want to produce the most hp out of the LNF, a HFC, IC, CAI and IC piping (and 3BAR MAPs) along with a dyno will net you about 375hp. While the stock components breathe enough for the K04 turbo, it's about the heat that those stock components breathe. The latest edition of the LNF (LTG, found in ATS, CTS, Camaro, Envision, Regal, Equinox, Terrain, Malibu...) is capable of over to 400hp with those mods and a dyno tune.
