1 - 6 of 6 Posts
So I bought the fitting from ZZP that adapts an oil line to the threads of the main galley holes. I'm installing an oil feed line to my turbo and for those of you that installed oil pressure gauges or feed lines themselves, what did you use to seal the brass adapter that screws into the block? copper washer? pipe dope? (I know its not a pipe thread). I really don't want these to leak.
Teflon paste
Anyone say differently? and if so why? also, should I torque it too the same spec as the oil gallery plugs? 26 ft. lbs.? I broke the last one from over tightening, but I just don't want it to leak
FWIW The oil galley plug uses the face of the bolt to make the seal, hence the torque spec.
Not doubting you man, You clearly know your stuff, thanks for the advice, I'll get my q tube of Permatex and get to work next weekend. Thanks again man
1 - 6 of 6 Posts
