1 - 5 of 5 Posts
Searching through the archives, looks like the JPM shifter assembly will be the best bet in order to change out the shifter knob. Mighty expensive, tho! Yesterday, I was trying to see how hard it would be to remove stock unit. Using a 4.5 mm bit, I could not get the set screw to budge. Looks like the factory has used some sort of loctite on the screw. I finally snapped the bit in two. Assume it is normal thread...lefty loosey, righty tighty. So...what can I use to loosen the set screw? Not feasible to use heat. Would a penetrating oil work on loctite?
I snapped one off also. It seems some are on much tighter than others. Heat is your only hope. Use a mini 2 gas tourch to keep the flame just on the set screw. I insulated well but scorched the padding also, but all went well.
Hi there!
Yes, there is thread sealant on the set screw. Heaven forbid it ever gets loose and starts an annoying rattle in the interior :rolleyes:
I didn't need to use heat, fortunately. If you're in that situation, it's a good excuse to go buy a mini butane torch, or a butane soldering iron with a torch attachment. As an aside, a butane soldering iron is a pretty handy tool to have for automotive electrical work.
1 - 5 of 5 Posts
