1 - 14 of 14 Posts
It seems my rear window has separated from the canvas at one spot and water is now getting in my car. I found this out the hard way while sitting in it using one of those brushless carwashes. That's when I discovered the true reason it's called the "waterfall". BTW, those carwashes put out a surprisingly large amount of water....:willy:
Anyone know how these are usually stuck together? Best repair method? Duct tape just doesn't fit the styling of a Solstice...:lol:
Thanks Rob! :thumbs:
I tried to do a search but came up empty-handed. Guess I just haven't gotten the hang of doing a forum search here...:willy:
My tip of the day:
When doing a search on this forum, use the "Google Search" in the pull down under search options. It works much better.
Which Sol is leaking the 06 or the 08? I see the TSB is about the 06's.
Buzzard,
The leak has happened randomly with all years.
I use google search exclusively. The forum search is pretty much worthless.
I knew that the thread existed so it was just a matter of finding the proper key words to bring it up. I used rear window solstice forum and it was on the top of the list.
Tiki, you are not alone in being frustrated by the forum search function.
I am just glad that I got the reference in here before TS got here first
Remember, if they dont find you attractive, they should find you handy
http://www.youtube.com/watch?feature=endscreen&v=4zWZJZPpRfc&NR=1
Had the same thing happen to my '08 a couple of years ago. Took the dealer about an hour to fix.
Happened to me, i had a small opening until I glued it together with gorilla glue. No problems since.
Sent from my iPhone using AG Free
When you take any convertible into a car wash, turn the fan speed up - it helps keep pressure on the weather seals and keep water out.
Discussion Starter #13
It is on my 06. (it's interesting to see which fairly common issue with our cars show up on which car...water pump - 08....rear windowb - 06....convertible top rubbing - 06....etc.)
Thanks everybody for the info, advice about my window and the search function...:thumbs:
Well we learned a long time ago that we shouldn't be going thru these auto car washes anyways AND if I recall the owners manual doesn't recommend them either... (Page 318 in the Sky manual states: "High pressure car washes may cause water to enter your vehicle"), Also in some places they also use recycled water, :eek: same crap they use down here to water golf courses...
HOWEVER, it IS a good way for you to find leaks...:D
whether you have them or not..:lol:
1 - 14 of 14 Posts
